Have you tried restarting/rebooting the Apple TV?
Jeff
I have an Apple TV 4, and I have never used a remote with one or two arrows on it, I've only used the touch remote that comes with it to skip around and fast forward/back, so sadly I'm out of ideas. Hope you get it sorted out. I guess with a new one you'd be set for 4K if and when you ever upgrade to that.
I guess the only other thing to check would be to see if there's a firmware update for your Apple TV 3 but it's weird that it'd stop working suddenly.
Using the ATV and its remote I don't see those on my screen. Odd. when I touch the touch pad I see a line on the bottom of the screen with numbers at each end, start time, how much is left in minutes, where the video is now in minutes, and a linear bar of time, if I tap it again the numbers change to time it will finish.
