Apple TV 3 (fast) forward and rewind not working
Ferdinand
Malmö, Sweden
Posts 541
Ferdinand Posted: Fri, Jun 14 2019 6:11 PM
Not sure if this the right place, but my ATV 3 doesn’t do ffwd and frwd anymore. ATV is connected with my BV10 but even with Apple remote the (fast) forward and rewind doesn’t work as should.
Is this a bug, is it malfunction i.e. would a new unit solve my problem. Looked on some Apple forums as well but no avail.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Fri, Jun 14 2019 7:26 PM
Have you tried restarting/rebooting the Apple TV?
Jeff
Ferdinand
Malmö, Sweden
Posts 541
Ferdinand replied on Fri, Jun 14 2019 9:07 PM
Yes i did Jeff, thanks. Tried different networks and nothing helped.
FFWD only 1st arrow (double speed) works , other 2 don’t
FRWD none of the arrows works.
Really weird ... i am leaning towards buying a new one and see if that works.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Fri, Jun 14 2019 10:09 PM
I have an Apple TV 4, and I have never used a remote with one or two arrows on it, I've only used the touch remote that comes with it to skip around and fast forward/back, so sadly I'm out of ideas. Hope you get it sorted out. I guess with a new one you'd be set for 4K if and when you ever upgrade to that.
I guess the only other thing to check would be to see if there's a firmware update for your Apple TV 3 but it's weird that it'd stop working suddenly.
Jeff
Ferdinand
Malmö, Sweden
Posts 541
Ferdinand replied on Sat, Jun 15 2019 5:56 PM
Thanks Jeff.
The arrows I referred to are the ones you see on screen. The 90degree tilted triangles.
I use Beo4 remote to operate ATV, but same problem is with orginal Apple remote.
I’ll have a word with Apple in the Malmö store.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sat, Jun 15 2019 6:03 PM
Using the ATV and its remote I don't see those on my screen. Odd. when I touch the touch pad I see a line on the bottom of the screen with numbers at each end, start time, how much is left in minutes, where the video is now in minutes, and a linear bar of time, if I tap it again the numbers change to time it will finish.
Jeff
Page 1 of 1 (6 items) | RSS
