Beosound 2 and Google Voice Control - to change volume levels
This post has 1 Reply | 0 Followers
kmspurway
Posts 23
kmspurway Posted: Sat, Aug 10 2019 7:34 AM
Wonder if I'm doing something wrong / need to check settings or do a full reset to my Beosound 2.
As it happily will change the volume via ("hey Google") voice control commands I give it when I use streaming services, but when I play music from my B&O NL / ML system & the B&O App it wont change the volume (using "hey Google" voice commands)
The Google Assistant works perfectly well for Google questions / searches when it is being used to play "B&O based" music btw
thanks for any suggestions
Hiort
Sweden
Posts 2,895
Hiort replied on Sat, Aug 10 2019 2:45 PM
kmspurway:
In that use case Google Assistant have no access to BS2.
I thinks that is a bit confusing.
Page 1 of 1 (2 items) | RSS
