Wonder if I'm doing something wrong / need to check settings or do a full reset to my Beosound 2.
As it happily will change the volume via ("hey Google") voice control commands I give it when I use streaming services, but when I play music from my B&O NL / ML system & the B&O App it wont change the volume (using "hey Google" voice commands)
The Google Assistant works perfectly well for Google questions / searches when it is being used to play "B&O based" music btw
thanks for any suggestions
kmspurway:As it happily will change the volume via ("hey Google") voice control commands I give it when I use streaming services, but when I play music from my B&O NL / ML system & the B&O App it wont change the volume (using "hey Google" voice commands)
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
