Hi everyone. Is it possible to operate the Sony PS3 with a Beo4? I think I have read somewhere on this forum a while ago there is a 3rd party device that will allow this. Do you have to also own a Beovision HD tv to control this?
If anyone has experience of this please let me know. Thanks.
You need to have b&o tv and then you can buy this:
http://www.re-bl.com/default.asp?show=supportdetail&ProductID=1&SupportID=32
or maybe you can by 238 converter from lintronic to use instead of b&o tv (convert beo4 code to re-bl code)
if they not have that in standard they probely can fix that for you
Thanks. I have been thinking about getting a Lintronic for a while now so maybe I'll contact them first and see if the re-bi is compatible. I guess if so the 238 converts signal for the re-bi which then converts for the PS3. Hope there isn't too much lag between signals.
Thanks for your advice.
Hi Graeme,
I also use the Logitech Harmony with my V1/Beo4. and it's fine for basic commands (which is all I use anyway - navigating the menus and start/stop/FFwd/Rewind). There's a little bit of a lag, but it's OK.
Jonathan
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
You could always go for a Bossbridge for B&O/PS3 from Bosscom, if I recall correctly they run about $129 USD
BeoGreg:I use RE-BL with Bv10 and PS3 since two and a half years. It´s just great and the customer service is excellent. It can work on batteries or power supply. What else ? Gregory Since 1995 : too much to re-write on the new site. Various Beosounds, Beovisions, Beolabs, Beocords, Beocoms...
