Hello,
Could anybody advise what îs the software i could use to properly patch my BeoLink NL/ML convertor , and where Could i load it down.
I Have got BL5s and BL3s connected to BV11-55 and also BeoCeter 2 and Beosound Moment and BL3500 in bedroom and BeoPlay V1 in separate rooms
Could anybody suggest me how to set it up to mare it work together.
thank you,
Vladimir
I'm not sure I understand what you're asking. Are you asking how to configure the converter?
With the converter plugged into your LAN, you simply enter it's serial number in your web browser. That brings up the configuration screen on your web browser.
For example, in the URL box you enter "blc-23026XXX.local" (I redacted the last 3 digits of my own serial number.)
From the web browser screen, you can update the firmware to the latest version.
