BeoLink convertor nl/mn software
nig940
Posts 2
nig940 Posted: Tue, Dec 31 2019 5:40 PM
Hello,
Could anybody advise what îs the software i could use to properly patch my BeoLink NL/ML convertor , and where Could i load it down.
I Have got BL5s and BL3s connected to BV11-55 and also BeoCeter 2 and Beosound Moment and BL3500 in bedroom and BeoPlay V1 in separate rooms
Could anybody  suggest me how to set it up to mare it work together.
thank you,
Vladimir
beojeff
USA
Posts 2,012
beojeff replied on Tue, Dec 31 2019 6:46 PM
I'm not sure I understand what you're asking. Are you asking how to configure the converter?
With the converter plugged into your LAN, you simply enter it's serial number in your web browser. That brings up the configuration screen on your web browser.
For example, in the URL box you enter "blc-23026XXX.local" (I redacted the last 3 digits of my own serial number.)
From the web browser screen, you can update the firmware to the latest version.
Page 1 of 1 (2 items) | RSS
