B&O alarm clock for my bedroom
This post has 12 Replies | 0 Followers
Steph
France
Posts 1,059
Steph Posted: Mon, Apr 15 2019 6:19 PM
I've recently moved in a new house and i'm searching for the best alarm clock in my bedroom.
Ideally, it would be placed on my bedside table and i could program it to wake up to the sound of the radio or another source (CD,...). Of course, i want B&O Wink
I do not have a subscription to a straming service. I own a BeoTime so it would be cool to use it to control the sound system or the speaker.
Could a BeoPlay M3 do the trick, or shall i buy a pre-owned product like the old Beosound 1 for instance ?
RaMaBo
near Munich
Posts 626
RaMaBo replied on Mon, Apr 15 2019 6:43 PM
any B&O system you like can be used with the BeoTime (flute). The old Beosound 1, a Beosound 9000, Beocenter 9500... Smile
Even a B&O TV masterlinked to the main room can act as wakeup speaker in the morning.
Ralph-Marcus
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Mon, Apr 15 2019 6:45 PM
The only streaming service you can leverage with a B&O product alarm-capable is TuneIn.
I personally leverage a BS 1 to wake me up with one of my favorite radio, and, when the streaming service is not available for any reason, a beep sound is generated instead.
I use an Essence remote to control it, very simple to operate when not fully awaken :-)
CB
> You are Here <
Posts 1,762
CB replied on Mon, Apr 15 2019 6:53 PM
Steph:
Bonjour Steph
No, the Beotime is IR and the M3 is BT.
Your second option is right
Steph
France
Posts 1,059
Steph replied on Mon, Apr 15 2019 7:31 PM
Thanks to Ralph-Marcus and to "the french gang"! Wink
And what about the BeoSound 8? I still have one  with an old iPhone 4. Do you think i can program it?
Millemissen
Flensborg, Denmark
Posts 14,680
The iPhone has an alarm clock built-in - that should do the trick.....when it is docked to the BS8.
RaMaBo
near Munich
Posts 626
RaMaBo replied on Mon, Apr 15 2019 9:38 PM
Might work...
But the BeoTime is a much more elegant solution. Smile
I think the Beosound 8 could also be controlled with a Beo4. The only 'problem' is to find the 'source' key to activate the Beosound 8. Maybe N.Music or N.Radio will do the job.
The Beosound allows to select a specific track, or radio station when the alarm time has come.
The alarm time gives the choice to select 'Radio' and '3' for example, or 'A.Tape' '7'...
Ralph-Marcus
CB
> You are Here <
Posts 1,762
CB replied on Tue, Apr 16 2019 6:30 AM
Steph:
I do not have a subscription to a streaming service.
Do you know that the M3 sports a timer ?
It’s able to wake you up everyday with TuneIn. In this case, the Beotime is of no use.
Steph
France
Posts 1,059
Steph replied on Tue, Apr 16 2019 2:40 PM
I didn't know for the M3 Yes - thumbs up
But i think it needs the phone and can't be operate via BeoTime?
CB
> You are Here <
Posts 1,762
CB replied on Tue, Apr 16 2019 6:48 PM
Steph:
Exactly, phone or tablet
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Tue, Apr 16 2019 6:50 PM
Steph:
M3, M5, A6, Core, even the Moment and surely other network connected products have the alarm capability.
Yes you need the App or a webrowser to configure it, and the App or a recent remote to operate it remotely.
ianpugh
Posts 42
ianpugh replied on Fri, Oct 11 2019 6:58 PM
Can you add an alarm with TuneIn? I have an M5 with this function but it doesn’t work for some reason.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Fri, Oct 11 2019 8:09 PM
Just tried to setup an alarm on my M5 with the App and it works fine. Both are at the latest software version.
Page 1 of 1 (13 items) | RSS
