I've recently moved in a new house and i'm searching for the best alarm clock in my bedroom.
Ideally, it would be placed on my bedside table and i could program it to wake up to the sound of the radio or another source (CD,...). Of course, i want B&O
I do not have a subscription to a straming service. I own a BeoTime so it would be cool to use it to control the sound system or the speaker.
Could a BeoPlay M3 do the trick, or shall i buy a pre-owned product like the old Beosound 1 for instance ?
any B&O system you like can be used with the BeoTime (flute). The old Beosound 1, a Beosound 9000, Beocenter 9500...
Even a B&O TV masterlinked to the main room can act as wakeup speaker in the morning.
Ralph-Marcus
The only streaming service you can leverage with a B&O product alarm-capable is TuneIn.
I personally leverage a BS 1 to wake me up with one of my favorite radio, and, when the streaming service is not available for any reason, a beep sound is generated instead.
I use an Essence remote to control it, very simple to operate when not fully awaken :-)
Steph:Could a BeoPlay M3 do the trick, or shall i buy a pre-owned product
Thanks to Ralph-Marcus and to "the french gang"!
And what about the BeoSound 8? I still have one with an old iPhone 4. Do you think i can program it?
The iPhone has an alarm clock built-in - that should do the trick.....when it is docked to the BS8.
Might work...
But the BeoTime is a much more elegant solution.
I think the Beosound 8 could also be controlled with a Beo4. The only 'problem' is to find the 'source' key to activate the Beosound 8. Maybe N.Music or N.Radio will do the job.
The Beosound allows to select a specific track, or radio station when the alarm time has come.
The alarm time gives the choice to select 'Radio' and '3' for example, or 'A.Tape' '7'...
Steph:Ideally, it would be placed on my bedside table and i could program it to wake up to the sound of the radio or another source (CD,...). Of course, i want B&O I do not have a subscription to a streaming service.
I didn't know for the M3
But i think it needs the phone and can't be operate via BeoTime?
Steph:But i think it needs the phone and can't be operate via BeoTime?
Steph:I didn't know for the M3
M3, M5, A6, Core, even the Moment and surely other network connected products have the alarm capability.
Yes you need the App or a webrowser to configure it, and the App or a recent remote to operate it remotely.
Can you add an alarm with TuneIn? I have an M5 with this function but it doesn’t work for some reason.
