jans:Hello In my kitchen I have an Essence controlled through IR eye. Here is my (theoretical) question. Suppose I would replace the Essence with a non-B&O streamer such as a Bluesound at a certain moment in time. Would it be possible to continue using the IR Eye? It would require some DIY to convert the electric pulses into IR signals. Anybody has a suggestion how to do this? As I said earlier, it is at this moment just a theoretical ‘thought experiment’ on a rainy Saturday. Nevertheless it would be interesting to know....
It is possible, yes. Using an Arduino, one could decode the IR commands coming from the B&O IR eye, translate them, and output them to the Bluesound. However, this is really nothing a person unexperienced with electronics and programming can accomplish easily.
Maybe have a look at some of the lintronic solutions: http://www.lintronic.dk/
First I’d like to ask, what made you think of the BlueSound?
Is your Essence a 1st oder 2nd gen?
Isn’t the BlueSound mostly managed by the app?
You could, if you are not sure, what you want/need, start with connecting the output (fixed) of the BlueSound to the line-in of the Essence.
This way you can keep the setup as is and listen to the sources of the BlueSound.....controlling the volume through the Essence, ir-eye, B&O remote.
Millemissen:First I’d like to ask, what made you think of the BlueSound? Is your Essence a 1st oder 2nd gen? Isn’t the BlueSound mostly managed by the app? You could, if you are not sure, what you want/need, start with connecting the output (fixed) of the BlueSound to the line-in of the Essence. This way you can keep the setup as is and listen to the sources of the BlueSound.....controlling the volume through the Essence, ir-eye, B&O remote. MM There is a tv - and there is a BV.
Sorry - would the wuality of the TuneIn stream not be exactly the same with BlueSound?
So, why this ‘thought experiment’......other than for the sake of a ‘thought experiment’?
On a side note - did you set the Essence up yourself? If yes, which cables did you use from the Essence to the Passive?
