Good mroning Beoworld!
I pickup a nice 4002, EN 20 styli looks good but the TT is not working correctly. Here are the issues:
- When I hit start:
- Tone arm lights up & moves to first track and needle drops as it should
- Strobe light above control panel does not light ( 33 or 45 ).
- Platter does not spin. ( has a belt as is in place )
- When I hit stop, it moves back to home position but make a high pitch noise like it need lube.
This is where I am at and would like a logical sequence to address these issues as sometimes when you fix one thing it may correct 2 things:-)
Thanks for your suggestions in advance!
