I got a bit of an issue, I was messing around with getting interlaced mode to work with my TV. But a few incorrect menus and Ive lost function of my remote to my MX4002. Theres plenty of power in the remote as its still shows the full LCD on the remote.I looked up the instructions on how to pair it but, the option I get when Press List (shift) and power are:
Option? Add? Remove?When I select add, nothing happens, it just moves to the remove screen. Iam not what happens or if theres a way to reset the remote to get some menus back? Or if the option for "Config" is under a different menu on some remotes?
Really need some help as I cant use the TV without the remote
