cant pair Beo4 remote with MX4002 - lost pairing
This post has 1 Reply | 0 Followers
vipermk2
Posts 3
vipermk2 Posted: Fri, Jan 3 2020 10:23 PM
I got a bit of an issue, I was messing around with getting interlaced mode to work with my TV. But a few incorrect menus and Ive lost function of my remote to my MX4002. Theres plenty of power in the remote as its still shows the full LCD on the remote.
I looked up the instructions on how to pair it but, the option I get when Press List (shift) and power are:
Option? Add? Remove?
When I select add, nothing happens, it just moves to the remove screen. Iam not what happens or if theres a way to reset the remote to get some menus back? Or if the option for "Config" is under a different menu on some remotes?
Really need some help as I cant use the TV without the remote
lawrencejmcook
Posts 742
Perhaps you’ve inadvertently set the TV to Option 0. Try resetting it to Option 1 or 4, per the manual.
Lawrence
Page 1 of 1 (2 items) | RSS
