Hi Beoforum
i really hope you can help here, I bought the C9 with stage and BEOREMOTE one yesterday. It is all setup, however the sound first appears when volume is up to 35 on the tv from stage. That’s not normal I think, it’s 1/3 if max volume. Any suggestions?
best
jacob
I use my Stage as a stand-alone speaker. I use AirPlay 2 and I have noticed that the volume is low initially but I can set it as needed and it gets loud enough. I also believe that some source content has lower volume than others. It does appear even in my case that the Stage volume is initially lower than my other BeoLab speakers. However, compared to my BL 6000 + BL 11 or BL 8000 + BL 2 the Stage has a more expansive sound stage. It distributes the sound better and has a more defined quality to it. Just my experience so far. Mine is on a table not wall mounted.
B&O in my life 😊:
Thank you, much appreciated. When playing Bohemian rhapsody Movie this morning I could easily adjust the volume up to 80. And it was not loud enough to fill a party up. My Beolab 3 is far louder. Don’t know why.
Hi
i have the same issue with my Beosound Stage connected with a new LGC9 TV and BeoRemote One. Volume is normal up to 35 Level.
Did you find a solution ? Thanks and regards, Armin
Do you guys mean the start up volume? as you can set that to what ever you like it to be in the app. or maybe I am misunderstanding?
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
thanks but it‘s not the start up volume (can be set in the App). I need to put the volume level on 35 or higher to have normal volume. Without connecting the LG TV with LAN to the beosound Stage, normal level is 10, und it seems for me that the sound is more powerfull. But without connecting by LAN, the BeoRemote would not work. Any assistance is much appreciated. Best regards, Armin
