Volume problem Beosound stage LGC9
Bendix
Posts 10
Bendix Posted: Sat, Feb 15 2020 10:23 AM
Hi Beoforum
i really hope you can help here, I bought the C9 with stage and BEOREMOTE one yesterday. It is all setup, however the sound first appears when volume is up to 35 on the tv from stage. That’s not normal I think, it’s 1/3 if max volume. Any suggestions?
best
jacob
Jaffrey2230
Washington DC
Posts 520
I use my Stage as a stand-alone speaker. I use AirPlay 2 and I have noticed that the volume is low initially but I can set it as needed and it gets loud enough. I also believe that some source content has lower volume than others. It does appear even in my case that the Stage volume is initially lower than my other BeoLab speakers. However, compared to my BL 6000 + BL 11 or BL 8000 + BL 2 the Stage has a more expansive sound stage. It distributes the sound better and has a more defined quality to it. Just my experience so far. Mine is on a table not wall mounted.
B&O in my life 😊:
  • Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office)
  • Beolab 6000 + Beolab 11 + Beosound Core with Essence Remote (Bedroom)
  • Beoplay A9 Mk2 (Living Room)
  • Beosound 1 with wireless dock (Portable)
  • Beosound Balance (Dining)
  • Beoplay H95 (Focused listening, travel)
  • Beoplay H9 (3rd gen) (retired)
  • Beoplay P6 (Portable)
  • Beotime wall clock (hallway entrance)
  • BMW X5 50i with B&O Audio Package (Commute/drive)
Bendix
Posts 10
Bendix replied on Sat, Feb 15 2020 2:25 PM
Thank you, much appreciated. When playing Bohemian rhapsody Movie this morning I could easily adjust the volume up to 80. And it was not loud enough to fill a party up. My Beolab 3 is far louder. Don’t know why.
Armin69
Posts 2
Armin69 replied on Wed, Apr 22 2020 8:02 PM
Hi
i have the same issue with my Beosound Stage connected with a new LGC9 TV and BeoRemote One. Volume is normal up to 35 Level.
Did you find a solution ? Thanks and regards, Armin
Mikipidia
Posts 2,169
Mikipidia replied on Thu, Apr 23 2020 12:32 AM
Do you guys mean the start up volume? as you can set that to what ever you like it to be in the app. or maybe I am misunderstanding?
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Armin69
Posts 2
Armin69 replied on Thu, Apr 23 2020 5:03 AM
Hi
thanks but it‘s not  the start up volume (can be set in the App). I need to put  the volume level on 35 or higher to have normal volume. Without connecting the LG TV with LAN to the beosound Stage, normal level is 10, und it seems for me that  the sound is more  powerfull. But without connecting by LAN, the BeoRemote would not work. Any assistance is much appreciated. Best regards, Armin
Page 1 of 1 (6 items) | RSS
