Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
Hi,can I use a Playmaker in the following configuration?
Beolab -> Playmaker -> Beosound.My intention: If my wife wants to use Airplay functionality on her computer the Playmaker switches on the Beolabs while the Beosound stays off. When I want to listen to all the sources of the Beosound, I active the Beosound and route the audiosignal to the playmaker and to the speakers.
I think that you can connect the Playmaker to the Beomaster 5 and use the AUX on the Beosound5 when you want to stream music.
No, that's not what I want.I have a Masterlink-Setup but I want to integrate Airplay-functionality for my wife, so that she can listen to the music on her computer via the Beolabs in Room X. Therefore I thougth that it would be the easiest solution to connect the Playmaker between the Beolabs in Room X and the Beosound in that room.Another solution would be to simply connect the Playmaker to AUX on the Beosound so that she can stream the music in every masterlinked room.
Thanks for your replies.Do I need to change option programming on a Beosound while using the Playmaker? What happens when I change sources on the Beosound via remote or simply adjust volume via remote? What happens on the system?
