Wondering if someone could tell me how to get MW when the push buttons have Am - FM only. When I press AM all I get is LW. What am I missing ?
Thanks Rudy
The user manual seems to be what you are missing.You switch between LW and MW by pressing down on the tuning wheel.
Thanks Martin I will check it out today.
Regards
Rudy
One other question, the output emitter bias resistors in the circuit show .39 ohms, R26-27, mine had 1 burnt & oc are .202 ohm, the closest I have is .22 ohms .
THere is a slight difference in the current reading, would it be better to replace both to .22 ?
The two emitter resistors should be identical.
Hi Martin,
