is there a higher software version then 2.4 for the beocom 5.
Sometimes under a phonecall the base lost connection with handphone.
My dealer started a case,but no (of couse) respons from our danish friends.
does anyone having the same problems?
Where do I find the S/W version? Mine doesn't have this issue!
Brengen & Ophalen
*#1234#
2.0
I tried all sw updates.
funny thing is,that in all sw updates the bug _base lost connection_ is still coming back!
Leslie: Mine doesn't have this issue!
If it is not broken.......
valve1: Leslie: Mine doesn't have this issue! If it is not broken.......
What do you mean by that?
I've been on software version 2.4 for a while now and I still have this problem once every week or two (and I'm never more than 20 feet from the base). On the phone you loose the connection, but the connection remains for the person you are on the phone with and they experience a very loud annoying static sound. I told my dealer and he sort of just shrugged his shoulders. Its a shame really as I love this phone when it works. For me, the problem is bad enough that I think twice when making an important or long call (i.e., a call with customer service, etc.); for those calls I use my cell phone (my iPhone, not my serene (great phone but it should never have been sold in the states...its not compatible with the frequency bands used here)).
Oké then i am not the only one.
B&O shame on you
What a pity !
I really like the look and feel of the BeoCom 5
I was ready to buy a desk phone for my new flat, in fact, my first B&O phone.
Should i buy the BeoCom 6000 instead ?
Then I'm the only one without any issues
Steph: What a pity ! I really like the look and feel of the BeoCom 5 I was ready to buy a desk phone for my new flat, in fact, my first B&O phone. Should i buy the BeoCom 6000 instead ?
Why not, how many you want? Have them in all colors...
Leslie: Then I'm the only one without any issues
Naughty naughty Bang&Olufsen, why did you gave me the only Beocom 5 that's working without any issues....shame!
Maybe you should check the S/W version on the Base, instead of the Handset?
My handset is on 2.30, while my base S/W is on 2.10... Don't know if that helps...
Beovision 11-55, BeoPlay V1 40, Beosound 9000, Beolab 8000's and 3 Beocom 5's...
Base 2.4. Handset 2.4
I tried everything......maybe a hammer
Is the latest software version still 2.4
koning: Base 2.4. Handset 2.4 I tried everything......maybe a hammer
Picture or it didn't happen
