Connecting new beosound 2 with vintage Beomaster3000+Beogram3300
skive1967
Posts 2
skive1967 Posted: Fri, Apr 10 2020 4:02 PM
Dear Forum,
I wish to connect my old Beomaster3000+Beogram3300 setup to my newly bought Beosoud 2 speaker system. However, I can't seem to find any sort of adapter or cable that could work with the beomaster and connect it to Beosound, which is limited to classic 'line in-jack'.
Now I'm starting worry, if it's at all possible to hear radio and vinyls through the Beosound 2 with my current setup?
Hoping to hear from you and a happy Easter to all! :-)
Jaffrey2230
Washington DC
Posts 520
If there is a headphone out on your beomaster you can just connect that to the Line-in of the BS 2 and it should work.
B&O in my life 😊:
  • Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office)
  • Beolab 6000 + Beolab 11 + Beosound Core with Essence Remote (Bedroom)
  • Beoplay A9 Mk2 (Living Room)
  • Beosound 1 with wireless dock (Portable)
  • Beosound Balance (Dining)
  • Beoplay H95 (Focused listening, travel)
  • Beoplay H9 (3rd gen) (retired)
  • Beoplay P6 (Portable)
  • Beotime wall clock (hallway entrance)
  • BMW X5 50i with B&O Audio Package (Commute/drive)
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Fri, Apr 10 2020 6:30 PM
It should be easy to connect.
Your BM3000 has  Tape-2 Line Out.  Use a stereo RCA to 3,5mm stereo mini jack to line in of the BS2. That should work.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi skive1967,
Welcome to Beoworld!
Yes, either option mentioned above will work, the Tape 2 Out option that Beobuddy mentioned is the best one to try, as this will give a good signal regardless of the volume setting on the Beomaster (whereas the headphone output needs the Beomaster volume to be turned right up).  All you need is a cable like this one to connect to the Beosound 2:-
https://soundsheavenly.com/hifi-av/112-498-minijack-to-twin-phono-rca-line-ipod-to-hifi.html#/2-length-1m
Kind regards, Steve.
Steve.
www.soundsheavenly.com
skive1967
Posts 2
skive1967 replied on Sun, Apr 12 2020 12:54 PM
Thank you very much for the help!
It works perfectly now!
Best!
Page 1 of 1 (5 items) | RSS
