Thank you, **thank you** for this photo!
It reminds me why I put up with my BV10-46 vs. the BV11: a more vertical aspect ratio and a broader metal frame. The BV11 looks "too much more like a TV" than the BV10, says my wife. She loves your fireflies, alas the wallpaper highlights the separation between the speaker cabinet and the screen. There is another thread where someone says they mounted the Stage a cm or two closer to the TV than the instruction sheet said, and liked the look better. I guess if you go with surface-mount cable trunking the wallpaper will camouflage it!
No doubt you'll get your combo working fine with a BeoRemote One BT (i.e. the Stage does *not* do PUC, uses the Ethernet cable & eARC). [Edit: not sure about other integrations like cable box, but I thought that was all done inside the LG, either via CEC or with the TV's integrated IR blaster -- that's how LG did the Sonos Playbase integration for example, because LG's remote is RF not IR.]
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
No, not looked at that yet.
The only "issue" i can see is that everything is rack mounted and the BV controls it all seamlessly.
The LG needs a "work around" with IR Blasters etc.
Another plus for Beovisions.
The Smart TV platform blows away the BV11 though.
PaulGiles:Yes, all works in progress, the fire place will be coming out and the TV will go in it’s place.
