I tried using a delay box but couldn't get it to remedy the delay issue. My solution was to connect the speakers to the NL/ML Converter instead of connecting the speakers to the BeoSound. Then, I mapped the sources to be controlled via an IR receiver connected to the NL/ML Converter. This solution actually opens up a lot of source control that can be mapped to the IR input of the converter. Note that you can't just start playing the music on the BeoSound and get sound via the speakers on the converter. You must use the IR input of the converter to get the source placing on the speakers.
