Hi
Hope someone can help me here please,
I have recently acquired a Beosound 5 / Beomaster 5 , i have attempted to transfer my music onto the Beomaster 5. Unfortunately i don't see my music on the Beosound 5, however the Storage Capacity has reduced as shown on the Beosound 5 display
I went through the following process to transfer the music
1) Mapping the drive manually using smb://192.168.x.x/bm-share
2) Copy and Paste my Itunes to the Beomaster 5
3) My music is listed in the folder BM-SHARE$
nigel123: Hi Hope someone can help me here please, I have recently acquired a Beosound 5 / Beomaster 5 , i have attempted to transfer my music onto the Beomaster 5. Unfortunately i don't see my music on the Beosound 5, however the Storage Capacity has reduced as shown on the Beosound 5 display I went through the following process to transfer the music 1) Mapping the drive manually using smb://192.168.x.x/bm-share 2) Copy and Paste my Itunes to the Beomaster 5 3) My music is listed in the folder BM-SHAREtiny_mce_markernbsp;
Your music should be copied to the Music folder. I have done exactly like
you, and copied my iTunes folder to the Music folder. Works like a charm
/Weebyx
Weebyx:Your music should be copied to the Music folder. I have done exactly likeyou, and copied my iTunes folder to the Music folder. Works like a charm/Weebyx
nigel123: In addition I would like to play Tidal (Deezer) through the BeoSound 5 is there a way of making the Beomaster 5 Bluetooth
Two different ways, actually.
Use an external USB soundcard - Behringer UCA 202 - for connecting a bt receiver via analog RCA in.
Or use a Beolink converter 1611 connected to the Beomaster 5 with a Masterlink cable - with the bt receiver connected to the 1611 via the Aux-input there.
Both way are described several times on the forum....please ask if you don’t find details.
Contact Steve Sounds Heavenly for the needed cables etc.
