Beosound 9000
This post has 1 Reply | 0 Followers
Brianpower
Posts 3
Brianpower Posted: Tue, Oct 27 2020 7:08 PM
How do I take my Beosound 9000 off the wall to disconnect from the Beovision 740 and then reconnect with 2 Beolab 1000 speakers.
Hungedu
United States
Posts 165
Hungedu replied on Tue, Oct 27 2020 7:20 PM
If attached to a wall bracket, you should be able to lift the system upwards, then gently pull it away from the wall bracket and detach the connections carefully.
BeoLab 5, BeoVision 7-55 MK2, BeoSound 5 Encore, BeoSound 9000, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, BeoLab 7-6, BeoSound 8, BeoTime (analog clock), Beo 4 remote.
Page 1 of 1 (2 items) | RSS
