How do I take my Beosound 9000 off the wall to disconnect from the Beovision 740 and then reconnect with 2 Beolab 1000 speakers.
If attached to a wall bracket, you should be able to lift the system upwards, then gently pull it away from the wall bracket and detach the connections carefully.
BeoLab 5, BeoVision 7-55 MK2, BeoSound 5 Encore, BeoSound 9000, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, BeoLab 7-6, BeoSound 8, BeoTime (analog clock), Beo 4 remote.
