I recently bought a set of bl 17, bl 18 and a bl 19 to handle the bass.
It is connected to my beolab transmitter 1, via WISA ( I WANT NO WIRES)
The beolab transmitter 1 is connected to my lg oled c7 via toslink.
I tried resetting the transmitter several times, adjusting the speakers (W/F/C) , with and without 2.1 subwoofer setting. And a lot of other things.
But in the end, the bl 17's delivers almost as much bass as my bl 19, and im actually really dissapointed. I barely cant hear the difference when i unplug the bl 19.
Is it just because b&o simply wont communicate with my lg c7?
I badly need help.
Im thinking of buying a used beovision avant 55" if that is the last possible solution.
Best Regards
Did you ever resolve your issue? I have the same issue with beolab 19 connected to beovision 11 wirelessly
