Poor bass from beolab 19- help me!
Kjaerslund
Posts 1
Kjaerslund Posted: Fri, Sep 6 2019 11:03 PM
I recently bought a set of bl 17, bl 18 and a bl 19 to handle the bass.
It is connected to my beolab transmitter 1, via WISA ( I WANT NO WIRES)
The beolab transmitter 1 is connected to my lg oled c7 via toslink.
I tried resetting the transmitter several times, adjusting the speakers (W/F/C) , with and without 2.1 subwoofer setting. And a lot of other things.
 But in the end, the bl 17's delivers almost as much bass as my bl 19, and im actually really dissapointed. I barely cant hear the difference when i unplug the bl 19.
Is it just because b&o simply wont communicate with my lg c7?
I badly need help.
Im thinking of buying a used beovision avant 55"  if that is the last possible solution.
Best Regards
Aussie Michael
Melbourne, AU
Posts 3,730
Hi.
My take is that I’m wondering if you have a surround sound processor in the middle of all of this ?
The transmitter 1 just makes your WISA speakers talk but doesn’t decode the surround sound “stuff”
So what you might be experiencing could be this ?
Or has it worked very well before and suddenly it degraded ?
What settings is your BL19?
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sat, Sep 7 2019 9:10 AM
The SUB 2.1 switch must definitively be ON for the TR1 to send the proper signal to the 19. The cut-off frequency is 120 Hz
Do you have B&O Input switch set to OFF if you have no other B&O product connected to it?
Have you tried with a music stream from another device connected to the TR1, e.g a smartphone?
I clearly hear the difference when the TR1 SUB 2.1 switch is on or off, all sound sources included.
Omid Moshtagh
Burlington Ontario Canada
Posts 50
Did you ever resolve your issue? I have the same issue with beolab 19 connected to beovision 11 wirelessly
Page 1 of 1 (4 items) | RSS
