Question is subject, what is the current and latest version of SW for the 1611 box?
kimhav: Question is subject, what is the current and latest version of SW for the 1611 box?
Don't believe anything later than 1.3 ?
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
Same - 1.3 I believe to be the latest SW. Something to do with being able to communicate with the BeoSound 5 rings a bell...
I'm not an installer though, so please forgive if I'm wrong!
(--- here was some wrong information ---)
Ok, thanks for the update; most time when looking for 1611 units it's often SW 1.3 and haven't seen any SW 1.61 units for sale but did see in other thread that it's possible to upgrade them to SW 1.6 by replacing software chip. Then again, I haven't opened any looked inside but have upgraded BL3500 to later SW by replacing pcb card which holds the SW.
Also, pitty that the current product section doesn't capture this kind of information and should be considered to be open up for edit by registered members or even better move of all this information to wiki based section instead (which it might be but then I haven't found it....).
TWG: Latest SW is 1.6 which enabled compatibility with MLGW: Forwarding light and control commands.
I think you are talking about Beolink active - type 1636 - which latest sw is indeed 1.6.
Question is about the Beolink converter - type 1611.
Stefan
stefan: I think you are talking about Beolink active - type 1636 - which latest sw is indeed 1.6. Question
Question
I am thinking the Same... I can’t se any reason to upgrade it to MLGW support because none the “old” datalink products support it anyway🤔
Søren
You're right! I mixed up Beolink active and Beolink Converter.
- Beolink active 1636 SW 1.6 - Beolink Converter 1611: SW 1.3
