BeoLink 1611 Latest SW version?
kimhav
Malmo, Sweden
Posts 314
kimhav Posted: Sat, Jun 20 2020 7:55 PM
Question is subject, what is the current and latest version of SW for the 1611 box?
OldJack
Split
Posts 371
OldJack replied on Sat, Jun 20 2020 8:21 PM
kimhav:
Don't believe anything later than 1.3 ?
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Sat, Jun 20 2020 9:17 PM
Same - 1.3 I believe to be the latest SW.  Something to do with being able to communicate with the BeoSound 5 rings a bell...
I'm not an installer though, so please forgive if I'm wrong!
TWG
Posts 1,672
TWG replied on Sun, Jun 21 2020 7:15 AM
(--- here was some wrong information ---)
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Sun, Jun 21 2020 1:26 PM
Ok, thanks for the update; most time when looking for 1611 units it's often SW 1.3 and haven't seen any SW 1.61 units for sale but did see in other thread that it's possible to upgrade them to SW 1.6 by replacing software chip. Then again, I haven't opened any looked inside but have upgraded BL3500 to later SW by replacing pcb card which holds the SW.
Also, pitty that the current product section doesn't capture this kind of information and should be considered to be open up for edit by registered members or even better move of all this information to wiki based section instead (which it might be but then I haven't found it....).
stefan
200 miles from Struer
Posts 2,920
stefan replied on Sun, Jun 21 2020 5:22 PM
TWG:
Latest SW is 1.6 which enabled compatibility with MLGW: Forwarding light and control commands.
I think you are talking about Beolink active - type 1636 - which latest sw is indeed 1.6.
Question is about the Beolink converter - type 1611.
Stefan
Soren
Denmark
Posts 115
Soren replied on Sun, Jun 21 2020 10:10 PM
stefan:
Question
I am thinking the Same... I can’t se any reason to upgrade it to MLGW support because none the “old” datalink products support it anyway🤔
Søren
TWG
Posts 1,672
TWG replied on Mon, Jun 22 2020 6:16 AM
You're right! I mixed up Beolink active and Beolink Converter.
- Beolink active 1636 SW 1.6
- Beolink Converter 1611: SW 1.3
Page 1 of 1 (8 items) | RSS
DigiCert Secured Site Seal
