Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
seethroughyou: Tried to connect it to my BL90 hoping to do in-app volume control so I wouldn’t have to go out of the Core and into BL90 on the app to do volume control.
You can actually control the volume in-app while using the Toslink output. For this, you need to go to Product Settings, then Configure, then Sound, then Optical-Out and then select "Volume regulated output".
It works perfectly with my BL20's connected to the Core over Toslink. I guess it should work with the 50's and the 90's as well?
jc:You can actually control the volume in-app while using the Toslink output. For this, you need to go to Product Settings, then Configure, then Sound, then Optical-Out and then select "Volume regulated output".It works perfectly with my BL20's connected to the Core over Toslink. I guess it should work with the 50's and the 90's as well?
seethroughyou: Tried that this evening several times and it doesn’t work sadly. No sound at all. Maybe your BL20 has powerlink cables attached to it.
Weird. And no, there are no powerlink cables between the BL20 and the Core...
- double -
seethroughyou:Tried that this evening several times and it doesn’t work sadly. No sound at all. Maybe your BL20 has powerlink cables attached to it. .
Razlaw:One thought.....I think that if the 50s/90s internal volume control is turned all the way down, then the app control you tried will not work. When I used the app control as you show, I had to have the 50s volume control turned up a bit, if I remember correctly. Beolab 50s Beolab 9s Beolab 12-3s Beolab 1s Beolab 6000s 2 pairs Beolab 4000s Beovision 7-55 Beovision 10-40 Beoplay V1 32 inch Beovision Avant 32 inch Beosound 1 (CD player) Beosound 3000 Beosound 5 Core Essence MKII Beoplay M5
