Is MM1 better cartridge than MM4
"MM cartridged"
Do you mean MMC cartridges?
If so, then yes, MMC1 was the best of the MMC1-5 range.Today, most cartridges will require a re-tip because of wear or damage and most will also require a new internal suspension, so you will be ableto upgrade even the lowest range MMC5 to better specs than those of the original MMC1.
