ist possible to connect a Beosound 5 to a Beovision Harmony ?
Yes, this is possible, the best option is to connect any extra speakers to the TV and then link the Beosound to the 3.5mm L/R In socket of the TV to play to the TV speakers.
For either the full Beosound 5 (with the Beomaster 5 base unit) or the Beosound 5 Encore (without the base unit), please use this cable from the Powerlink socket of the Beosound to the TV (please set the Beosound volume to around 70 to give full volume control from the TV remote):-
https://soundsheavenly.com/televisions/158-2365-powerlink-to-beovision-14-harmony-eclipse-horizon-avant-ng-2017-on-cable-link-your-audio-system-to-your-new-tv.html#/2-length-1m
Kind regards, Steve.
Steve.
www.soundsheavenly.com
hfinette: Hi, ist possible to connect a Beosound 5 to a Beovision Harmony ?
For full control and integration both ways you need the ML/NL Converter.
Anything is possible, but for your sanity it may not be desirable.
NL ML Converter is possible to use with the Harmony ?
Millemissen: hfinette: Hi, ist possible to connect a Beosound 5 to a Beovision Harmony ? For full control and integration both ways you need the ML/NL Converter. MM
MM I love your humour!
Full control and integration whilst referring BeoSound 5, I salute your sarcastic whit!
Playing Netradio from the BS5 on the Harmony/SoundCenter.....would be great - wouldn’t it!
