Beovision Harmony / Beosound 5
hfinette
Posts 34
hfinette Posted: Wed, Oct 14 2020 7:36 PM
ist possible to connect a Beosound 5 to a Beovision Harmony ?
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Yes, this is possible, the best option is to connect any extra speakers to the TV and then link the Beosound to the 3.5mm L/R In socket of the TV to play to the TV speakers.
For either the full Beosound 5 (with the Beomaster 5 base unit) or the Beosound 5 Encore (without the base unit), please use this cable from the Powerlink socket of the Beosound to the TV (please set the Beosound volume to around 70 to give full volume control from the TV remote):-
https://soundsheavenly.com/televisions/158-2365-powerlink-to-beovision-14-harmony-eclipse-horizon-avant-ng-2017-on-cable-link-your-audio-system-to-your-new-tv.html#/2-length-1m
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Millemissen
Flensborg, Denmark
Posts 14,680
hfinette:
For full control and integration both ways you need the ML/NL Converter.
StUrrock
Posts 995
StUrrock replied on Wed, Oct 14 2020 8:44 PM
hfinette:
Anything is possible, but for your sanity it may not be desirable.
hfinette
Posts 34
hfinette replied on Wed, Oct 14 2020 9:06 PM
NL ML Converter is possible to use with the Harmony ?
StUrrock
Posts 995
StUrrock replied on Wed, Oct 14 2020 9:55 PM
Millemissen:
hfinette:
MM I love your humour!
Full control and integration whilst referring BeoSound 5, I salute your sarcastic whit!
Millemissen
Flensborg, Denmark
Posts 14,680
Playing Netradio from the BS5 on the Harmony/SoundCenter.....would be great - wouldn’t it!
Page 1 of 1 (7 items) | RSS
