I,m offerd an old MkII with some small troubles reading discs. Is it a lot of work to repair this? Might it be enough with a single cleaning of the lens?
You should probably count on the worst scenario that the laser needs to be replaced, that in itself is a major issue as B&O no longer has stock of lasers. So basically you have to buy a chinese brand of Ebay and hope that it works. Also need to verify if that 9000 has had the laser repaired before by B&O because it would have probably been upgraded to the MK3 laser
Thanks for the reply. I didn't buy this BS this time and it feels right :-)
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
