Beosound 9000 MkII
Andreas
Larvik Norway
Posts 21
Andreas Posted: Mon, Nov 9 2020 8:56 PM
I,m offerd an old MkII with some small troubles reading discs. Is it a lot of work to repair this? Might it be enough with a single cleaning of the lens?
BenSA
Durban, South Africa
Posts 1,404
BenSA replied on Tue, Nov 10 2020 6:00 AM
You should probably count on  the worst scenario that the laser needs to be replaced, that in itself is a major issue as B&O no longer has stock of lasers. So basically you have to buy a chinese brand of Ebay and hope that it works. Also need to verify if that 9000 has had the laser repaired before by B&O because it would have probably been upgraded to the MK3 laser
Andreas
Larvik Norway
Posts 21
Andreas replied on Fri, Nov 20 2020 1:59 PM
Thanks for the reply. I didn't buy this BS this time and it feels right :-)
seethroughyou
UK
Posts 999
I was interested in a BS9000 but for similar reasons stopped like you.
It seems a very big shame that B&O can’t supply this amazing legend and pinnacle of B&O’s history with parts. I can foresee a time when all BS9000s in the world will become doorstops or end up in recycling.
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
Page 1 of 1 (4 items) | RSS
DigiCert Secured Site Seal
