Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Sorry - are you sure, you touched the black dome while programming the lamp number?
Does your LC2 respond to fingertouch? Are you able to set on-off by touching the black dome?
A kind of factory reset should be LIGHT - SETUP - 0 - STORE - GO - 4, if I remember correctly.
This info should be - as all useful info - in the old forum.
If your LC2s don`t respond to touches you will need new domes.
Hope this helps
Stefan
stefan:Sorry - are you sure, you touched the black dome while programming the lamp number? Does your LC2 respond to fingertouch? Are you able to set on-off by touching the black dome? A kind of factory reset should be LIGHT - SETUP - 0 - STORE - GO - 4, if I remember correctly. This info should be - as all useful info - in the old forum. If your LC2s don`t respond to touches you will need new domes. Hope this helps Stefan
