Numbering LC2s does not work
Hiort
Sweden
Posts 2,895
Hiort Posted: Thu, Nov 22 2012 9:41 PM
I'm adding a third LC2 to my light setup, but I cannot number the new LC2.
I follow the manual exactly.
It just not reacting to any number.
I've also tried to change number on the two existing but that does not work either.
Any advise?
Is it possible to "Factory reset" or similar?
stefan
200 miles from Struer
Posts 2,920
stefan replied on Fri, Nov 23 2012 5:46 PM
Sorry - are you sure, you touched the black dome while programming the lamp number?
Does your LC2 respond to fingertouch? Are you able to set on-off by touching the black dome?
A kind of factory reset should be LIGHT - SETUP - 0 - STORE - GO - 4, if I remember correctly.
This info should be - as all useful info - in the old forum.
If your LC2s don`t respond to touches you will need new domes.
Hope this helps
Stefan
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Nov 23 2012 10:17 PM
stefan:
Hope this helps
Stefan
Touching the dome did the trick!
Why did they not mention that in the manual?
At least not the Swedish, what I can see.
Thanks Stefan!
Page 1 of 1 (3 items) | RSS
