Hi all,
What's the best way to connect a pair of BL18 and a BL19 subwoofer to BeoSound Core? (sound quality wise)
BL19 has a low-pass filter button but does the Core/BL18 automatically adjust accordingly to remove the bass from BL18 (high-pass filter) ?
There are 2 ways to connect BL18 to the Core with a daisy chain:
1. Via Powerlink: Core -> Powerlink -> 1st BL18 -> Powerlink -> 2nd BL18
2. Via Optical: Core -> Optical -> 1st BL18 -> Optical -> 2nd BL18
How do you connect BL19 to these setups ?
My understanding from the BL19 manual is that you can do
1. Via Powerlink: Core -> Powerlink -> 1st BL18 -> Powerlink -> 2nd BL18 -> Powerlink -> BL19
If I'm wrong please let me know.
It's not totally clear how do you connect BL19 to the Optical setup. (BL19 only has 1 PowerLink port).
Thank you for the clarification about the cross overs and hi-pass filter in BL18.
So daisy chaining with PowerLink between Core, BL18 and BL19 is possible.
Is it possible to have BL18 connected via Core's Optical-Out and BL19 connected via Core's PowerLink in the same time ?
Or should I connect the BL19 with the PowerLink from the second BL18?
