BeoLab 18+19 and BeoSound Core connection
pig30n
Posts 35
pig30n Posted: Mon, Jan 4 2021 2:39 PM
Hi all,
What's the best way to connect a pair of BL18 and a BL19 subwoofer to BeoSound Core? (sound quality wise)
BL19 has a low-pass filter button but does the Core/BL18 automatically adjust accordingly to remove the bass from BL18 (high-pass filter) ?
There are 2 ways to connect BL18 to the Core with a daisy chain:
1. Via Powerlink: Core -> Powerlink -> 1st BL18 -> Powerlink -> 2nd BL18
2. Via Optical: Core -> Optical -> 1st BL18 -> Optical -> 2nd BL18
How do you connect BL19 to these setups ?
My understanding from the BL19 manual is that you can do
1. Via Powerlink: Core -> Powerlink -> 1st BL18 -> Powerlink -> 2nd BL18 -> Powerlink -> BL19
If I'm wrong please let me know.
It's not totally clear how do you connect BL19 to the Optical setup. (BL19 only has 1 PowerLink port).
Duels
England
Posts 2,553
Duels replied on Mon, Jan 4 2021 6:13 PM
If you are using cables then daisy chain the BL19 from the second BL18.
The 19 does have a low pass filter but the 18s do NOT have a high pass filter. So the 18s will continue to play their normal frequency range in this set up.
Using a Transmitter 1 for WISA connection would deal with this and adjust the sound management and cross overs automatically. This is really how they were meant to be used unless you have a BeoVision which would also handle it.
pig30n
Posts 35
pig30n replied on Mon, Jan 4 2021 7:00 PM
Thank you for the clarification about the cross overs and hi-pass filter in BL18.
So daisy chaining with PowerLink between Core, BL18 and BL19 is possible.
Is it possible to have BL18 connected via Core's Optical-Out and BL19 connected via Core's PowerLink in the same time ?
Or should I connect the BL19 with the PowerLink from the second BL18?
Page 1 of 1 (3 items) | RSS
