Beogram 2000
This post has 3 Replies | 0 Followers
ElDocHollywood
Posts 2
ElDocHollywood Posted: Sun, Feb 7 2021 6:34 PM
Hello and thanks for having me.
I recently acquired a Beogram 2000 and have a couple of questions.  I have searched and searched but my limited brain is not pulling up the answers :).
Can you manually move/start on a track of your choosing?  I don't know were to grab it or if the mechanism allows you to pick up and move it.  I know it is a silly question but I rarely want to listen to a full side of every record.
Also, should the player make a click noise as it is turning?  Never audible when it is playing through speakers.  I only noticed it when I was setting it up and putting on the new belt.  Sounds consistent like it it the mechanism at work.
Thanks and again, I appreciate the help.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Feb 8 2021 6:37 AM
Push the tonearm to where you want to start listening, and press PLAY.
Use QUE to lift the tonearm while playing, push the tonearm with a finger to where you want to go and press PLAY (or QUE again).
The deck makes a small click when you press start, but it should then run silent.
If the motor makes a noise it's probably because its rubber suspensions have dried out allowing the motor to sag down.
Ask at Beoparts for replacement suspensions and a new belt.
Weebyx
Denmark
Posts 1,213
Weebyx replied on Mon, Feb 8 2021 8:58 AM
ElDocHollywood:
Is the click noise from the motor or platter ? I had a BG2000 with clicking noise from the motor, where I needed to disassemble the motor(not easy, they are not designed to be serviced), and there was a plastic piece that was loose, which caused it to hit the magnets when it turned.
Glued it back together, and noise was gone.
/Weebyx
ElDocHollywood
Posts 2
Thanks.  When i get my drivers back from recone, I will take a video of it spinning and show you what I mean.  I appreciate it, guys...
Page 1 of 1 (4 items) | RSS
