Hello and thanks for having me.
I recently acquired a Beogram 2000 and have a couple of questions. I have searched and searched but my limited brain is not pulling up the answers :).
Can you manually move/start on a track of your choosing? I don't know were to grab it or if the mechanism allows you to pick up and move it. I know it is a silly question but I rarely want to listen to a full side of every record.
Also, should the player make a click noise as it is turning? Never audible when it is playing through speakers. I only noticed it when I was setting it up and putting on the new belt. Sounds consistent like it it the mechanism at work.
Thanks and again, I appreciate the help.
Push the tonearm to where you want to start listening, and press PLAY.Use QUE to lift the tonearm while playing, push the tonearm with a finger to where you want to go and press PLAY (or QUE again).The deck makes a small click when you press start, but it should then run silent.If the motor makes a noise it's probably because its rubber suspensions have dried out allowing the motor to sag down.Ask at Beoparts for replacement suspensions and a new belt.
ElDocHollywood: Hello and thanks for having me. I recently acquired a Beogram 2000 and have a couple of questions. I have searched and searched but my limited brain is not pulling up the answers :). Can you manually move/start on a track of your choosing? I don't know were to grab it or if the mechanism allows you to pick up and move it. I know it is a silly question but I rarely want to listen to a full side of every record. Also, should the player make a click noise as it is turning? Never audible when it is playing through speakers. I only noticed it when I was setting it up and putting on the new belt. Sounds consistent like it it the mechanism at work. Thanks and again, I appreciate the help.
Is the click noise from the motor or platter ? I had a BG2000 with clicking noise from the motor, where I needed to disassemble the motor(not easy, they are not designed to be serviced), and there was a plastic piece that was loose, which caused it to hit the magnets when it turned.
Glued it back together, and noise was gone.
/Weebyx
Thanks. When i get my drivers back from recone, I will take a video of it spinning and show you what I mean. I appreciate it, guys...
