Hi, none of my other beovisions have a blinking light in standby, I have set it to option 6 and everything works as it should (it is a link TV in the kitchen), other than the blinking red light (no pun imtended)
Is this normal or have I done something wrong?
Hi, no it's not been asking for one.
Did you get anywhere regarding this? My BV6-26 has started to flash its red led as well. It works happily other than flashing it's red led. Any pointers anyone as to what that may mean and how it could be fixed?
I believe I fixed it. (Re) Set the BV6-26 to V.Opt 1 (which I believe is the factory default) - and voila: no blinking led anymore.
