Beovision 6-22 Red Light Blinks in standby
This post has 4 Replies | 2 Followers
Andrew
Frinton, UK
Posts 917
Andrew Posted: Wed, Jul 31 2013 9:46 PM
Hi, none of my other beovisions have a blinking light in standby, I have set it to option 6 and everything works as it should (it is a link TV in the kitchen), other than the blinking red light (no pun imtended)
Is this normal or have I done something wrong?
MartinW
Posts 389
MartinW replied on Wed, Jul 31 2013 10:00 PM
Does it need a PIN code?
Andrew
Frinton, UK
Posts 917
Andrew replied on Wed, Jul 31 2013 10:11 PM
Hi, no it's not been asking for one.
tb59427
Posts 68
tb59427 replied on Tue, Mar 9 2021 7:49 AM
Did you get anywhere regarding this? My BV6-26 has started to flash its red led as well. It works happily other than flashing it's red led. Any pointers anyone as to what that may mean and how it could be fixed?
tb59427
Posts 68
tb59427 replied on Tue, Mar 9 2021 9:35 AM
I believe I fixed it. (Re) Set the BV6-26 to V.Opt 1 (which I believe is the factory default) - and voila: no blinking led anymore.
Page 1 of 1 (5 items) | RSS
