Power switch for external amplifiers Beomaster 7000
This post has 12 Replies | 1 Follower
garrard301
Posts 16
garrard301 Posted: Sun, Jan 3 2021 9:23 PM
I am using non-B&O external amplifiers with my Beomaster 7000. I would love to be able to turn the amplifiers on/off with a remote relay as I switch the Beomaster 7000 on and off - as I do with my Beocenter 9000, using a 4001 Remote Mains Switch. Or any alternatives?
Is there any way I can wire a spare 4001 to the Powerline DIN of the 7000 (replacing the plug) to trigger the relay in the 4001? I am sure this question has been asked before, but I couldn't find it in the forum.
Weebyx
Denmark
Posts 1,213
Weebyx replied on Mon, Jan 4 2021 8:55 AM
garrard301:
The Powerlink connections on the BM7000, has a trigger voltage to power on the active speakers, you can use this. Search for powerlink pinout on the web, and you will find what you need.
/Weebyx
Guy
Warwickshire
Posts 2,590
Guy replied on Mon, Jan 4 2021 11:49 AM
The 4002 remote mains switch should work fine if you change the plug (or build an adaptor) so that it is triggered from powerlink pin 4.  I have used it in this manner, and have also successfully used the trigger from an RJ45 powerlink socket in a Playmaker.
However, the 4002 specifically states that the device controlled should be a maximum of 500W, so check your amplifier or use a different solution.
EDIT: Just realised that you were talking about the 4001 (not 4002), which I think is the US version and has a difference max power rating - possibly of 1500W if the pictures I have just googled are correct!  Other details should be the same, and the user manual is on the site.
There's a DIY relay circuit here: http://beotech.beoworld.org/circuit.htm
Guy
Warwickshire
Posts 2,590
Guy replied on Mon, Jan 4 2021 12:33 PM
Further to the above, B&O did make an adaptor that would allow you to use the 4001/2 with a Powerlink socket: (saves cutting any wires, and allows you to still use the PL socket)
garrard301
Posts 16
Thanks, everyone, for the useful info.
I have just acquired a working 4001 with the plug already cut off, so I can now wire one to trigger from a PowerLink outlet. I understand pin 4 for the + power, so presumably pin 2 for the second wire?
Wanted to check before I do anything stupid...
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Jan 27 2021 10:52 PM
Yes, pin 2 is correct for the other wire (ground).
See Peter Pan's 2 Aug post here for a diagram: http://www.hifi4all.dk/forum/forum_posts.asp?TID=32157&PN=1&TPN=7
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, Jan 31 2021 9:09 PM
I was browsing Amazon and came upon this switch, which could be an option for people wanting to trigger more powerful mains devices from a Powerlink (or USB) 5v trigger.  It's a bit pricey, but a possible option for those unable to find the B&O remote mains switch or unwilling to make their own.
https://www.amazon.co.uk/dp/B0765WBGK6/?coliid=I8QO0DLXT03IS&colid=3IR721MNWWYM8&psc=1&ref_=lv_ov_lig_dp_it
I haven't bought one, but saved it in my 'wish list' just in case Big Smile
garrard301
Posts 16
garrard301 replied on Sun, Jan 31 2021 10:51 PM
This should work, too, for the US/Canada, and is much cheaper!
Like the look of this, as the mains includes ground, unlike the B&O trigger boxes.
Might pick one up...
Iot Relay - Enclosed High-Power Power Relay for Arduino, Raspberry Pi, PIC or WiFi, Relay Shield: Amazon.ca: Electronics
Guy
Warwickshire
Posts 2,590
Guy replied on Mon, Feb 1 2021 9:46 AM
garrard301:
Yes that looks much better value - pity they don't do a 240v UK version.
Did you get your B&O remote switch working OK?
garrard301
Posts 16
I bought the Iot relay from amazon (Canada link above) to power up the two big amplifiers I use with my Beomaster 7000, and it's now arrived. It was very easy to link it to pins 2 and 4 of the Powerlink DIN, and it works excellently. Two relay controlled outlets, one that works in reverse, and one that is always on. Good value. The only problem I had was that there were no instructions, only a link to a web page that didn't have them, but a quick chat to the manufacturers, and I was on the instructions page. A B&O two pin relay box now happily doing the switching on my Beocenter 9000. Thanks for all the advice!
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Mar 6 2021 6:12 PM
Great news - glad that you are happy with the setup.  The Lot relay sounds like a great bit of kit; we just need a UK version!
Guy
Warwickshire
Posts 2,590
Deleted - double post.
garrard301
Posts 16
This is the one you mentioned above.
Keene AC Powerswitch Relay Or Trigger Control for Iot Arduino Raspberr – K2Audio
Keene AC Powerswitch Relay Or Trigger Control for Iot Arduino Raspberry Pi ESP32 KPS1: Amazon.co.uk: DIY & Tools
10A would suggest a power rating of up to 1850 ish watts.
Just connect Powerlink pins 2 and 4 to the little green terminal, keeping polarity, and that's it (though I see this one also has a plug socket for the continuous trigger, and for a usb trigger).
It is pricey, though!
Page 1 of 1 (13 items) | RSS
