speaker set up for harmony
This post has 25 Replies | 1 Follower
pastaj
Posts 53
pastaj Posted: Fri, Feb 19 2021 4:13 AM
Hi everyone!
I just set up my harmony (basic setup, still waiting on the mic) and WOW, what a ton of settings and options. Im wondering what is a good place to start for speaker roles. I have a pair of 50s up front and 18s in the rear. The harmony has 3 channels and i set them all to "center front" for now but seems redundant to run them all the same. Sounds like i have a similar setup to Mikipedia and i was hoping for some insight into setup to get the most out of these speakers. I have noticed, just with my Core set up to run the 50s alone, they perform differently depending on if they are connected via powerlink vs optical. I am now running everything via WISA and just want to make sure im getting everything i can out of the speakers and the setup. Any guidance would be greatly appreciated. Thanks!!
MaxH
Posts 126
MaxH replied on Fri, Feb 19 2021 2:22 PM
Mikipedia will give you great advice but for my money you need to turn the two outside centre channels on the Harmony down - especially if you don't have so much room between the speakers - because they are so powerful. You will need to experiment to see how you can get the best from vocals in that setup but you have all the tools you need to do it.
You need to connect the 50s via powerlink or you won't get anything like the best out of them but my 18s are fine via WISA connection.
Are your 18s at the rear of the room or just behind the seating position? It makes a great deal of difference whether you use them as rears or surrounds.
pastaj
Posts 53
pastaj replied on Fri, Feb 19 2021 2:39 PM
Thanks for the reply!!
ok, so by "turn them down" do you mean the gain/level? the 50s are about 3 feet to the left and right of the TV.
In regards to the 50s, i meant the interconnect between the master/slave. are you referring to this connection or do you mean directly connecting them to the TV? the specs on the sound guide for the 50s seem to imply that the WISA connection provides for high quality sound transmission. Are you saying that by directly connecting the speakers to the  back of the harmony gives better sound? i have noticed that the bass and the sound was much richer and warmer when i had my core connected via powerlink but when i switched to an optical connection, the sound output (when volume levels were held the same) was much lower compared to the powerlink connection. I dont know much about cables and why this would be but i was under the impression that optical/toslink was supposed to be the best quality sound. but for my taste, the 50s were BOOMING when they were hooked up to the core via powerlink.
i have the harmony front and center, then the 50s as a traditional front L/R. The 18s are slightly behind the listening position, on either end of my couch. Pretty much a standard 5.1 surround setup. But is there a way to mimic, or technically HAVE, a 7.1 channel setup since there are 3 speakers within the harmony? i understand that setting the L/R in the harmony to front L/R would be a waste since the 50s are far more capable. If this were your system, how would you set it up? thank you!!
pastaj
Posts 53
pastaj replied on Fri, Feb 19 2021 2:43 PM
Also, for those that saw my first forum post a few months ago, i did end up getting the receiver1 and have it running one of my SVS SB-16s and with some simple bass mgmt, its working and now i just need to tweak, but for those interested, it is possible to run non BO subs via receiver1 and harmony with some slight bass mgmt. I will keep posted.
also, would love to hear everyones opinions on setup options for the harmony and my current speaker group. thank you. very grateful!
MaxH
Posts 126
MaxH replied on Fri, Feb 19 2021 3:19 PM
Sounds like you are having fun :-)
As far as cabling and the various options in your setup wait for Mikipedia's input  - in fact it would be a great Twitch show on its own (hint, hint).
I was referring to the speaker levels on the Harmony. For TV and YTube I have the two centre outsides set as -1.5 db and the centre as 0db but for other inputs (Netflix, for example) I have the outsides set as -2.5db and the centre as -1db.
For music I only ever use my front speakers (no Harmony or anything else).
The 18s in the position you describe should be set to surround.
pastaj
Posts 53
pastaj replied on Fri, Feb 19 2021 3:33 PM
amen!  as most of us on here, i feel like a kid on christmas. I picked up my harmony soundcenter yesterday and installed the GX mount and the GX screen in a reasonable amount of time. I find that stuff so much fun. now comes the hours and hours of tweaking settings for that perfect sound. I agree, if i had some 90s id only use those too ;-) hahahaha, one day, i went from a pair of e8 earbuds to all of this stuff now, its addicting....and EXPENSIVE. lol.
anywho, really appreciate the input! this is a great place to get info that is not easily obtainable and im grateful for this wealth of knowledge here.
one last thing, im sure its a sound mode or speaker setup issue but i was briefly watching Billions on prime (nice pair of 90s in that dudes apartment) and the audio sounded spot on for surround sound, but when i was on netflix, the audio while watching the brief previews they give you when you scroll over the content, i noticed the sound was very echo-y. As if you had a DSP mode applied, think dance hall or orchestra mode, etc. Is this normal or is it a sound mode setup issue that i need to sort out? thanks!
MaxH
Posts 126
MaxH replied on Fri, Feb 19 2021 4:05 PM
E8s to 50s, 18s and a Harmony - love it Big Smile
Have a good tinker but, if it were me, I would get the basics right first.
Definitely no WISA on the 50s but I don't have a Core so wait for Miki or one of the technically able people to put you right on the best way to hook them up.
As well as a mic get a stand and don't forget to keep the mic pointing up. If the 50s are new, in my experience, it's a good idea to recalibrate after using them for a period of time. Also, a simple db meter on your phone comes in useful.
I have different sound settings for Netflix, Prime and TV and it also makes a difference (IMHO) whether you play these through Apple TV or not so there is even more fun(?) until you get your preferences set.
Once you are happy you can set these different sound settings on the My buttons on the remote.
I have Netflix, Prime, Apple TV and Apple TV (playing only 90s) as MY buttons so switching sound settings is automatically done.
As you will find out there are multiple ways to experiment to achieve different sound settings so good luck  - you have some great gear :-)
Millemissen
Flensborg, Denmark
Posts 14,680
@pastaj
As for the channels of the Harmony with connected L/R speakers.
Go to 14.30 here: https://youtu.be/svIUxzKzI8E
Millemissen
Flensborg, Denmark
Posts 14,680
@pastaj
pastaj
Posts 53
pastaj replied on Fri, Feb 19 2021 4:39 PM
well that pretty much answers that! thanks!
pastaj
Posts 53
pastaj replied on Fri, Feb 19 2021 4:43 PM
Are there adjustment screws for the harmony speakers to fine tune the alignment? i found the ones on the back of the tv that move the screen closer or further way so the speakers clear the screen, but my speakers are slightly out of alignment and want to trim them. thanks!!
Mikipidia
Posts 2,169
Mikipidia replied on Fri, Feb 19 2021 4:56 PM
Posted something similar in your other thread, basics first Big Smile
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Sandyb
Posts 2,186
Sandyb replied on Fri, Feb 19 2021 4:59 PM
Congrats on the new setup!
Like Max above, I only use my front (i.e left and right) 50s for music - none of my other speakers are engaged, and certainly not my BV speakers, and neither my rears.
Unless you room is extremely large, there should be no need for anything other than the 50s for music, unless you really have a preference for engaging the 18s too.
pastaj:
pastaj
Posts 53
pastaj replied on Fri, Feb 19 2021 4:59 PM
he has arrived......lol been waiting to hear your opinion. thanks!
Mikipidia
Posts 2,169
Mikipidia replied on Fri, Feb 19 2021 11:19 PM
pastaj,
Here are some of the things for the Harmony MM and I said in another thread. Firstly though, before we speak about ''optimising'' wire in the 50's and set them up correctly as they will for 80% dedicate the performance of your system.
MM said:
''Normally what you call ‘left back’ would be the speaker placed and set as the left rear speaker behind you.
A ‘surround back’ does not really excist - surround speakers are those, that are placed beside the listening position.....and back would mean speakers that are placed at the back aka rear speakers.
You really should consult the Technical Sound Guide found on the B&O website - there you find good explanations for speaker placement and assigning these to the different roles. Also google for the Dolby layouts of 5.X/7.X speaker configurations.
As for how to use (or not) the L/R’s of the Harmony, when you want a multichannel setup, there are different takes on this.
As with all audio and audio configuration it depends on your room - and indeed on how far you have placed the BL5’s from the tv....also on your seating posions in front of the tv (especially when more people are listening).
You will have to experiment a bit - one good starting point would be to engage the LR as Center, set these up with a difference of 3 db to the C of the Harmony and set the distance of the C to approx 20 centimeters further away than the L/R.
See this video interview with Geoff Martin, where this also is discussed (head for 15:00):
As always....don’t be afraid of trying things out, just keep record on what you are doing in order to find the right settings for you/your setup, once you have finished testing.
Note: you can easily make to Speaker Groups with different settings and switch between these........maybe even one for solo-listening and one for when you are more people.''
I said:
''geoff was talking about the left and right of the speakers inside the harmony/eclipse/avant. They are labeled as bv harmony L and bv harmony R. So you set the bv harmony C to the correct distance and at 0(if that is desired/confirmed with db meter in refference to the other speakers in the speakergroup) you then you check the same for distance and output for the bv harmony L qnd bv harmony R (both of those are also set to center). You then bump the bv harmony C by +1db and the bv harmony L & R bump those down -3db. Then you ad an additional 20cm to the bv harmony C channel for distance.
That is what Geoff said to try, just doing the Harmony C channel for center speaker channel only isn’t “wrong” or “bad” just default and a different way of doing it.''
And:
''Generally in terms of setup with a 5.1 track, the “rear” speakers are the surround audio track. With 7.1 the “rear” speakers are in the back track position and so in that case they should be in the back position, because the the surround speakers are the middle ones in the 7.1 tracks.
The left and right of the harmony aren’t on on mine either, you can turn them on (as MM reffered to, by Geoff) but i think it makes the center a bit boomy. That’s up to you, to me it makes more sense on an avant or eclipse as the harmony already kicks butt''
But please sort the 50's and the physical setup of the Harmony first!
jowus
Posts 161
jowus replied on Sat, Feb 20 2021 1:19 PM
pastaj:
Hi Pastaj,
Did you just got the Speakers of the Harmony or you got the whole TV? I think, I read one of the your post about ordering the Speakers of the Harmony? Anyway Good luck!
Mikipidia
Posts 2,169
Mikipidia replied on Sun, Feb 21 2021 12:04 PM
Any updates?
pastaj
Posts 53
pastaj replied on Mon, Feb 22 2021 3:14 PM
just posted one. sorry, im new to "forums" and seem to have  2 running posts about the same topic. I posted to the other one just now. But yes, i watched Edge of Tomorrow yesterday and the system BLEW me away. i couldnt believe how great it sounded, and this is with NO mic tuning. Just a tape measure and a dB meter. So far so good but im having lip sync issues. It seems like everytime i have an issue, there is some small, easy fix that sets it right, its just with SO many settings and whatnot, it makes it difficult to figure out but when i do, it solves the problem immediately. Had a horrible echo when watching Ocean's 13 intro music and went into 50s configurator and found them to be set to high latency. Switched to auto and voila!
question about bass management...when no subwoofer is hooked up, and bass mgmt is ON, all the speakers are set to enable filtering to the 50s. Is this necessary? in theory, its taking low end from the center and the 18s in the rear and sending it to the 50s. my understanding. Is this necessary though? It seems that all the speakers in my setup would be capable of handling a fairly full frequency range and the system might sound "fuller" when all speakers are receiving the entire signal?
thanks again!!
and to the other individual's question, yes i just bought a harmony sound center as i already had the LG GX panel that I coincidentally bought prior to starting this B&O journey. Was very easy to install with the GX mounting bracket and the connections were easy, aside from the glitch my 50s were having that a power cycle was able to solve.
MaxH
Posts 126
MaxH replied on Mon, Feb 22 2021 3:24 PM
My thinking is that the 50s are the best speakers to handle the bass so why not?
Miki may have another view though
pastaj
Posts 53
pastaj replied on Mon, Feb 22 2021 4:23 PM
i dont disagree but im wondering if it really makes a difference. or would it be better to just run all speakers "unrestricted" per se. I guess i can just play with watching the same scene of a movie with and without bass mgmt on and see the difference. but this does all feel a little preemptive since i still haven't done the proper mic setup. Does the mic set up ALL parameters? i know it does distance and levels but what about the bass mgmt settings of pan and balance, etc? thx!
MaxH
Posts 126
MaxH replied on Mon, Feb 22 2021 5:25 PM
You need to read this before you do anything else Smile
https://support.bang-olufsen.com/hc/en-us/articles/360042434432-Beolab-50-technical-sound-guide
Millemissen
Flensborg, Denmark
Posts 14,680
How a beolab speaker can handle bas is (among other factors) a matter of the sound pressure level.
If you drive your setup at a relatively low volume level, you won’t notice much difference.
However, if you - which you probably will :-) - listen at higher volume, it is recommended to use the bas management functionallity of the Sound Center.
Please be aware, that the mic setup procedure is a matter of configuring the BL50’s (not the entire multichannel setup).
During the mic setup you can make presets, that you afterwards - when setting up the entire speaker setup can integrate with the Sound Center.
Here is a link to a setting up video and others - very helpfull for those who want to do the setup on their own:
https://youtube.com/playlist?list=PLRPmJ785xnMi0nBHAKH25GbHItnj_1E8Q
Also reading this entire thread can be helpfull:
 https://archivedforum2.beoworld.org/forums/t/43644.aspx
Millemissen
Flensborg, Denmark
Posts 14,680
Deleted
Mikipidia
Posts 2,169
Mikipidia replied on Tue, Feb 23 2021 1:49 AM
Lets continue in this one then.
How do you play prime video? App on the panel or through an apple tv? I’ve never had any lipstnc issues, then again I am on a C9 panel and lg made them slightly different. Since you used the tv before it may be a good idea to factory reset it, just in case. With a normal Harmony setup you do as little as possible before you can get in to it and download the b&o app and then set it up further. Just an idea to start with a clean slate.
I would keep the bass management on honestly as the 18’s don’t really like a full lfe channel at high volume. They’ll be ok, but you could run in to abl. If you really wanted to you can pull back on the bass diverting a bit. Auto sets it to -100db, but you could try -90db or something like that.
The standard movie preset is pretty much a golden compromise, as in it’s freaking fantastic out of the box, but change it to what ever you like. There is a reset button Stick out tongue
jowus
Posts 161
jowus replied on Mon, Mar 15 2021 11:42 AM
pastaj:
thanks again!!
Wow Pastaj, didn’t the Harmony Speakers alone cost you a fortune? I would love to see your Setup! Stories like this, makes this forum a Place to be! Good luck in all your endeavors!
pastaj
Posts 53
pastaj replied on Thu, Mar 18 2021 3:28 PM
im grateful to be in a position to enjoy these products. my dad has had the same pair for 30 years and i guess i was just wired to gravitate towards BO. Dont know how to post pictures but its a great looking setup :-)
Page 1 of 1 (26 items) | RSS
