Connect Sonos Amp with Beosound 3200 connected with Beo Penta speakers
This post has 4 Replies | 2 Followers
Rvergracht
Posts 1
Rvergracht Posted: Thu, Apr 8 2021 4:42 PM
Hello,
I am wondering if there exist the possibility to wire up my Sonos amp with the beosound 3200 in order to play the Sonos music with the 3200 connected Penta's.
Can anyone advise?
Kind regards
Ronny
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, Apr 8 2021 5:38 PM
If the Sonos amp has a line level output you can feed that into the Beosound's AUX input and play to your Pentas.
If there is a line output, let us know what type of connection (possibly L/R phono or 3.5mm jack socket) and we can advise what adaptor.
Millemissen
Flensborg, Denmark
Posts 14,680
@Guy
There is no such, nor a digital output.
And that is the problem :-(
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, Apr 8 2021 6:32 PM
Millemissen:
@Guy
Ah yes.  Having searched, I see that you'd need a Sonos Connect or the newer Sonos Port in order to have a line-out.  And it all looks a bit pricey!  Better to add an Airport Express.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Ronny,
Welcome to Beoworld!
Please change the Sonos Amp to Sonos Port or Sonos Connect, then it can easily play into the Beosound with this cable:-
https://soundsheavenly.com/bang-olufsen/52-72-stereo-rca-twin-phono-to-beosound-aux-input-din-socket.html#/2-length-1m
If you prefer to use a cheaper option like Airport Express, please let me know and I can help with the connections.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (5 items) | RSS
