Hello,
I am wondering if there exist the possibility to wire up my Sonos amp with the beosound 3200 in order to play the Sonos music with the 3200 connected Penta's.
Can anyone advise?
Kind regards
Ronny
If the Sonos amp has a line level output you can feed that into the Beosound's AUX input and play to your Pentas.
If there is a line output, let us know what type of connection (possibly L/R phono or 3.5mm jack socket) and we can advise what adaptor.
@Guy
There is no such, nor a digital output.
And that is the problem :-(
Millemissen: @Guy There is no such, nor a digital output. And that is the problem :-( MM
Ah yes. Having searched, I see that you'd need a Sonos Connect or the newer Sonos Port in order to have a line-out. And it all looks a bit pricey! Better to add an Airport Express.
Hi Ronny,
Welcome to Beoworld!
Please change the Sonos Amp to Sonos Port or Sonos Connect, then it can easily play into the Beosound with this cable:-
https://soundsheavenly.com/bang-olufsen/52-72-stereo-rca-twin-phono-to-beosound-aux-input-din-socket.html#/2-length-1m
If you prefer to use a cheaper option like Airport Express, please let me know and I can help with the connections.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
