Beogram 2000 Tonearm Height.
seesalt
Posts 5
seesalt Posted: Sat, Jun 5 2021 2:59 PM
Let's get right to it:
My tonearm wont go down properly to reach the record.
Now, i have looked inside the manual Where it states you van set the tonearm by adjusting a screw as shown:
The Problem is, there is no L screw shown in the manual.
Does anyone now how to set the hight properly cause i can't seem to find a way to adjust it.
FYI it's the Beogram 2000 5821
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Jun 5 2021 3:33 PM
Most likely the lifting mechanism has broken at the tonearm base.
It's quite common.
seesalt
Posts 5
seesalt replied on Wed, Jun 9 2021 9:00 PM
Any way to fix this or is this a lost cause?
Dillen
Posts 13,191
Dillen replied on Thu, Jun 10 2021 6:33 AM
Is it broken?
seesalt
Posts 5
seesalt replied on Thu, Jun 10 2021 10:05 PM
 I can't really tell if it's broken or not.  I have no idea what to look for.
There is obviously something wrong. But then I Have to take it apart to see I think
Al I can say is that before it was in this state, maybe a couple hours before the picture, i probably bumped into it and now it won't get any lower than You see above.
ProGram
59269 Beckum, Germany
Posts 383
ProGram replied on Fri, Jun 11 2021 2:05 PM
You may have to disassemble the tonearm. I've had both broken hinges, which I replaced with some aluminium. It works quite well.
seesalt
Posts 5
seesalt replied on Sun, Jun 27 2021 1:34 PM
It seems like the part you described is also 'wack' on my end. No idea how I would fix this though.
Dillen
Posts 13,191
Dillen replied on Sun, Jun 27 2021 3:58 PM
seesalt:
How about the idea you were just given above?
Page 1 of 1 (8 items) | RSS
