Difference between Beovision 8-40 mk1 and mk2?
This post has 7 Replies | 0 Followers
Master123456789
Posts 237
Master123456789 Posted: Thu, Jul 1 2021 7:51 PM
I have just bought a BV 8-40 mk2. Besides from the 3 hdmi ports - what is the difference then? I cannot see any change at the picture.
It got a DVB-T2 tuner but that is also possible in the mk1.
mbee
Paris, France
Posts 1,842
mbee replied on Thu, Jul 1 2021 9:50 PM
As far as I remember the mkii brought Masterlink compatibility, which the mki didn’t have.
Millemissen
Flensborg, Denmark
Posts 14,680
My MK1 had - but it was an add-on - came as an (in my case) already installed module, that also included an extra scart input………if my memory serves me well 😉
Master123456789
Posts 237
Mk2 did not got masterlink, so that is not a difference.
Some say it got a 200hz picture - is that right?
Millemissen
Flensborg, Denmark
Posts 14,680
Master123456789:
What do you mean by that - I know of no MK2 without ML.
And yes - now that you mentioned that - the MK2 had the 200hz….not that I could see any difference.
There might also have been some other differences for different markets as for the tuner…..
Master123456789
Posts 237
at my mk2 there is no masterlink
Millemissen
Flensborg, Denmark
Posts 14,680
Master123456789:
Well, well….I can only conclude that we can not answer the question of the op.
Too many options - he’d probably need the type number for that.
Master123456789
Posts 237
so most of all, not any difference but the 3 hdmi. If there were any other someone would know.
Page 1 of 1 (8 items) | RSS
