I have just bought a BV 8-40 mk2. Besides from the 3 hdmi ports - what is the difference then? I cannot see any change at the picture.It got a DVB-T2 tuner but that is also possible in the mk1.
As far as I remember the mkii brought Masterlink compatibility, which the mki didn’t have.
diisign.com
My MK1 had - but it was an add-on - came as an (in my case) already installed module, that also included an extra scart input………if my memory serves me well 😉
Mk2 did not got masterlink, so that is not a difference.Some say it got a 200hz picture - is that right?
Master123456789: Mk2 did not got masterlink, so that is not a difference.Some say it got a 200hz picture - is that right?
What do you mean by that - I know of no MK2 without ML.
And yes - now that you mentioned that - the MK2 had the 200hz….not that I could see any difference.
There might also have been some other differences for different markets as for the tuner…..
at my mk2 there is no masterlink
Master123456789: at my mk2 there is no masterlink
Well, well….I can only conclude that we can not answer the question of the op.
Too many options - he’d probably need the type number for that.
so most of all, not any difference but the 3 hdmi. If there were any other someone would know.
