BeoSound 9000 glass door adjustment.
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 Posted: Fri, Jun 21 2019 9:03 PM
Does anyone know how the closed position of glass door can be adjusted. On one of my BS9000 its not parallel to the aluminum base plate, i.e.about 3 mm to low in the front. I have seen this issue a couple of times so I guess its a known problem,- or?
Schletti82
Posts 128
Open the Aluminium plate to the Control Panel. There is a small hole on the left side where you can put an imbuss inside to adjust.
on the other side you have to remove the aluminium plate. There you can see the hole too.
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Sat, Jun 22 2019 12:46 PM
Thanks Smile
wantonandfurious
Posts 9
Is this the hole that is set in an angle ("downward" toward glass door)? Looks a bit like the socket on a Fender Stratocaster, if you know what I mean?
matador43
Posts 1,373
matador43 replied on Fri, Apr 23 2021 9:30 AM
Yes, it's that one.
Alan01
Posts 1
Alan01 replied on Wed, Sep 15 2021 6:22 PM
Hi Mate I have the same problem with my Bang & Olufsen 9000 and the glass door is a little off line, slightly touching the CD arm… did you resolve the problem with adjusting the screws??
Page 1 of 1 (6 items) | RSS
DigiCert Secured Site Seal
